431Bird
Hey got a few quick questions. 1) What torque specs do you torque down the rocker shaft bolts? Also you just put antiseize these right? Or does a guy put blue locktite on these? Wouldnt think you would want locktite on the bolts in aluminum, all new to me. Something happen with me, mine backed out causing the rocker shaft to break. 2) Should I running studs on the shafts instead, if so what brands trying to find a part # aint havin any luck.
