Is my current wiring correct? Green wire straight from regulater to alternator. I have the blue wire out of the regulator going to the alternator and into this blue wire I have two other wires spliced into it: 1 blue wire from the ballast resisitor and a blue wire w/white trace on it (the two wires that were previously connected to the ignition side of the old mechanical regulator).
However, I found these other instructions where it looks like I'm supposed to splice the green and blue wires together.
"Basically, a wire is added to the second field brush on the alternator. On the original alternator, this brush is grounded to the case of the alternator, so you'll need to change the alternator to a 1970 or newer style. The second field wire is connected to the outside plug on the newer voltage regulator (two plugs, one is in the middle, one is on the outside). The original field wire that ran to the "FLD" plug on the original voltage regulator (green wire) needs to be connected with the wire that ran to the "IGN" side of the original voltage regulator. This wire (both the old FLD and the old IGN) need to be connected to the center plug on the newer voltage regulator as well."
