This will be a little off topic but it still applies.
Today I was over at Rich's place,
@CoronetDarter. Here is his Coronet:
He just finished the Classic Auto Air installation and it all looks fine. He put the vacuum pump on it along with these hoses and gauges:
The gauges wouldn't go over 10" of vacuum and bled off to zero when the pump was turned off so we figured it has a leak.
Part two:
This '68 Dart also has a CAA air system, installed by the previous owner.
We tried to pull a vacuum on it but the gauge numbers went positive.
It blows warm and the compressor clutch stays still. The high and low sides measured about 80 psi each with the engine running.
We bypassed the high-low pressure switch but it didn't encourage the compressor clutch to engage. The window in the manifold showed that refrigerant was present but who knows how much.
My own car still blows warm despite being charged 4 times since 2022.
The tech at CAA said that these systems
have to be serviced different than OEM late model systems.
I don't know enough about this to just go my own way or call the guy a worry wart.
Dwight said that these systems are to be charged with the engine off. He said that the compressor clutch is to be spun 15-20 times before charging and after charging. The system takes a specific amount of refrigerant, no more, no less. It is either 24 or 28 ounces, I have it written down somewhere and it is clearly listed in the instructions. He said that you are not to invert any canister or tank to fill the system, it must be filled with the tank upright.
I have seen it done both ways so I don't know what is the advantage of doing the "right" way as per the CAA instructions and Dwight's advice.
Rich plans on doing the same thing that I do....To take his cars to a shop to
close the book on the system.
We don't have the experience nor the leak detection tools to find leaks.
