interior lights
prhousejr
9:46 AM
city
Ok I have everything on my 68 Satellite working now except for the dome light. Map light works, console light works, ignition switch light works. So am I correct in thinking that the door switch is ok? The bulb in the dome is good. Where would you guys look next?
And did these cars have a door buzzer? if so where is it? That is not working.
The wire for the dome runs down the driver's A pillar and plugs in behind the kick. Check to make sure it's plugged in
Exactly the info I needed. Thanks a bunch 69 runner!!!!!
