arizona satellite
I am working on a 340 and it will stall out while driving and sometimes just idling.i have checked float level and fuel press( electric pump) and that does not seem to be the problem. I notice that the ballast resistor is freaking HOT once it cools down it will start and run. I was thinking of replacing the system with an MSD box. it has the mopar electronic ign in it now( not a mopar performance kit but a stock harness spliced into the original harness. Am I on the right track thinking ign?? it is not a vac leak, fuel overload or at least not that i can tell. the 340 has a rather large cam(unsure of the spec) and a 2500 stall that I dont think is enough for the cam but the motor will stall in park so that eliminates the trans dragging down the motor.
