mr.belvedere
- 12:49 PM
- Jul 20, 2008
- eagle mills, new york
hopefully someone has been down this road and can give me a little guidance.
67 gtx, headlights will flicker after about 20 minutes of operation, and will eventually just fail after about 2 minutes of that. the car did this 18 years ago when i first got it, so i replaced the h/lamp switch and the connector because it was melted. no problems after that, but now years later after the resto, happening again.
new h/lp switch
good dash harness from donor car
new dimmer swich
good dimmer connector(not melted)
check of dash harness(nothing melted/no broken wires)
check of forward lamp harness(nothing melted/no broken wires)
all other lamps function perfectly. directionals, hazards, brake lamps, etc. and they all work as they should when used in combination. lamps are are very bright, and grounds are all good (i'm a fanatic about clean, solid grounds). not sure if the tailights are going out at the same time or not, and i dont remember if my dash lights went out with the headlamps, i was concentrating more on getting home in one piece. no blown fuses either. anyone know if there is a circuit breaker in the switch?
very frustrated. possibly another bad h/lamp switch? looking for my wiring diagram, but i am open and very appreciative to suggestions.:confused:
new h/lp switch
new dimmer swich
