6PKRTSE
My water pump/housing is studded also. It does make everything much easier. In fact my entire engine is ARP Studded.When i put a motor plate in mine, i made some studs to replace the water pump housing bolts. That way even with the pump housing off, the motor and plate stay together. I made my studs because i had access to a lathe and the raw stock neccessary, but i'm sure a little research at arp can find what you would want.
