Is this energy kit a good deal?
dude,,,if you put that on your road runner...it will drive like a truck....that poly DONT give a nice ride, and feels like youre in a cinder block. i wouldnt do it....but im not you..... it squeaks and what not....youll hate it!
Didn't think so but I was getting mixed messages about poly parts, going to just go with rubber factory style parts thanks Just picked up 4 KYB gas adjust shocks for $128 shipped with the rockauto discount code.
good move with the rubber....otherwise...youll be tearing it back apart....2wice the expense and who needs that?
lol
There are two kinds of "poly".
Poly-urethane, which is the squeaky stuff...
and poly- graphite, which is self lubricating with impregnated graphite.
I got poly-graphite on my Belvedere with no squeaks and a nice firm ride. Got front and rear sway bars w/ poly-graphite also. Had to go with adjustable front strut rods to work properly with the poly LCA bushings. Rubber is fine for a stock rebuild, I like to drive mine into the corners a little................
I tried to go with poly urethane, but both the upper and lower control arm bushings did not fit properly, so i just went with stock moog rubber bushings and have a perfect fit. I will be using poly urethane on some other locations, like the k-frame mounts, but nothing that will move up and down and squeak!
