Is this engine knock or normal. You tell me!
Glowing pipes is a good thing as long as they all glow.
Yeah. It’s all good on that front now. It’s one thing after another with this car. In that video I only revved it to about 2000 rpm. Engine will rock if I really feed it the onion
Right there almost with you I built this motor over 10 years ago and now its close to start.
Just keep at it when its right just gas and go with some easy checks.
The sound is tinny. Something is hitting the inspection cover or maybe you have the wrong dust plate?
Yes sir, oil is clean as could be. Just checked
He wanted you to pull the dipstick out , leave it out , and run it , because maybe it was hitting the rotating assembly inside the motor
Not to check the oil
Amongst what others have mentioned
Yup did that. He asked to check for a metallic substance on the dipstick while it was running. I didn’t just check for oil…..
Does the engine have a windage tray?
The noise sounds internal bottom end.
