MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
- 5:00 AM
- Nov 24, 2015
- Moreno Valley, So California
Remember that on any firearm that you need 2 types of protection.
1. Is for lubrication of the metal/moving parts. Use the proper rated lubes, WD-40 was designed as a penetrant/water displacer (WD).
2. Is for the exterior/furniture. Here you need a sealer of some type.
I have used both personally and professionally ( I managed a chain of gun stores in the 80's) Believe it or not, Lemon Pledge.
It will remove finger prints and puts a coating of wax on the wood and metal surfaces. Repels moisture and dirt/dust. Just a quick wipe with a microfiber cloth and you are done. In the gun stores you were constantly wiping off the guns after the customer handled it. Shiny and no prints.
Oils trap moisture and attract dust/dirt ( oil floats on top of water),
Wax seals the surface( think of waxing your car) it repels water/ dirt/dust.
You wouldn't put oil/grease on your cars paint to protect it. You would use a wax/sealer. Same concept.
I have used it on all my hand guns, rifles, shotguns for over 40 years both in the field (winter hunting trips) and at the range.
Guns still look new with no rust. Also smells good.
Use lubes sparsely, just a few drops where needed. I have use Break free CLP since it came to market. I got 4 gallons of it from a friend in the Marine Corps. The Military used it and stored it in 2- 1 gallon bottles per box.
Since then there have been several good lubes come to market. Test and use what you prefer. No WD-40. for guns.
I spend much of my time in the shop lol. Went to the 'lickher' store at around 10 and the rain slacked off but by the time I got home, it was heavier. Thing is, I have a carport behind the shop where I park the beater Dakota and that's what I use for short trips and the lickher store is about a mile away and the better junk stays clean and dry in the shop....and when I got home I pulled in under the carport and walked into the shop from the back door. Yeah, I'm a back door boy
I know that feeling. lol
