I was talking about a used OEM crank, and the rod journals do wear oval as the "Thrust" is where the crank pushes the rod up. Really, your asking me those question like I have no idea what I am talking bout??
Before the crank, bearing bores or bearings are measured the clearance variance is speculation. Obviously if you know about bearing bores you also know that getting them all dead on to the ,000X' is not always a "simple line hone". The crank journals may or may not be out of round. So how do we know it needs to be .010"/.010". As far as there is no .001" clearance for journal diameter. You never use this as a rule of thumb? Can you explain when this doesn't work? We still have not been told what the intended purpose of the original posters build is. It's always easy to tell someone that something has to be a certain way. When in fact what works in most instances may fall out of the ideal range.I was talking about a used OEM crank, and the rod journals do wear oval as the "Thrust" is where the crank pushes the rod up. Really, your asking me those question like I have no idea what I am talking bou
most if not all aftermarket crank manufacturers are going to want a different spec then factory. Don’t forget those factory specs are 50+ years old. Crank material along with advances in bearing material come into play. Do what you like but as another poster mentioned, I would never set a bearing clearance for any engine in any application at .0011 ever. That .0011-.0036 mentioned earlier is a very wide tolerance....Using the 0.001 per inch of journal like with rods, it appears the front two are tight...
There is no such rule, and I am not sure where you read that. The spec is what the manufacturer puts in their service manuals for their requirements. Chrysler says that they want to see 0.0011" to 0.0036" for main bearing clearance and 0.0009" to 0.0034" for rod bearing clearance. While I like to see 0.002" to 0.0025" for the mains, I wouldn't be afraid to run up to 0.0035" for the mains.
I have seen that rule for piston clearance, but even they give the actual amount to multiply by bore size to determine the clearance, AND if you are using any "power adders", that number changes.
You are correct, he hasn't stated his usage model yet, and still hasn't, which I haven't gone further, but he has said that the crank is new and I can tell you for a fact that the measurements he stated in post #5 do not represent a new crankshaft. Either the crank is defective, or he incorrectly measured it. He needs to go back and remeasure the crank mains and if he gets the same measurements, the crank needs to be returned as it is defective.Before the crank, bearing bores or bearings are measured the clearance variance is speculation. Obviously if you know about bearing bores you also know that getting them all dead on to the ,000X' is not always a "simple line hone". The crank journals may or may not be out of round. So how do we know it needs to be .010"/.010". As far as there is no .001" clearance for journal diameter. You never use this as a rule of thumb? Can you explain when this doesn't work? We still have not been told what the intended purpose of the original posters build is. It's always easy to tell someone that something has to be a certain way. When in fact what works in most instances may fall out of the ideal range.
Doug
Yeah,Did you torque up the block and check the housing bores without the main bearings? Crank looks ok if the measurements are accurate. My guess is it’s just a little tighter on 1&2 housing bores. A good machine shop can easily touch up the block if that’s the case. Did you set the bore gauge up off the same mic you used to check the crank? When your measuring things to the 0.0001 it’s always good practice to do so. Looks like a simple issue.
