jpurcell
1963 Sport Fury Convertible, 318, auto trans...
Was having some electrical problems so tore into the wiring. Oh Boy! PO had rewired lots of stuff I am dealing with. My question concerns the Ammeter Black wire (R-6A). The wiring diagram shows a junction box (big black circle) that joins Ammeter Black (R-6A) with Ignition Red (J-1), Light Switch Black (B-1 terminal, not sure wire #... my diagram is cut off), and Fuse Block Red-Tr (Q-3).
This is all under the dash. The PO had spliced the Ignition, Light Switch, and Fuse Block wires together in two different places on the Black R-6A wire instead of using a junction block. I am assuming it is missing, but where would I look? What is the best way to correct? Is there a part number for the right junction block or a good generic replacement? I don't really want to splice the wires, but would that be OK?
Thanks in advance!
Thanks in advance!
