SublimeSixpack
Would you mind giving me an idea approximately of what the gap is/was between your intake and the block (between the heads) front and rear on your engine?
I ask because I recently installed Magnum heads and a Magnum type intake manifold on a rebuilt 318. When I fired it up and ran the cam in I experienced coolant leakage issues in three of the corners where intake, heads and block meet. I'm now trying to determine whether the leakage was at the intake or the heads. I pulled the intake off and found no obvious reason for the leaks. After cleaning surfaces I mocked the intake back up with the used gaskets and only have 1/8" gap front and rear. Seems that the LA engines with LA heads I've done have had more of a gap there. Is a smaller gap normal when using the Magnum heads? I'm wondering about the machine work that was done to the heads. Would appreciate any insight on this.
