pearljam724
Wondering if b body LA small blocks and big blocks share same alternator ?
I thought so, Thank you. What about a starter motor ?those alternators were used on everything. single pulley, double pulley , single field , 2 field , in a variety of amperages. there was also a GM style used , I forget the name, Delco maybe not sure
Dakota starters work great and weigh quite a bit less.I thought so, Thank you. What about a starter motor ?
I think the brand name you are searching for is: LEECE-NEVILLE. They sort-of resemble a Delco 12SI series, a high output design. The Leece-Neville units were used in high amperage needs....police vehicles and luxury car requirements.those alternators were used on everything. single pulley, double pulley , single field , 2 field , in a variety of amperages. there was also a GM style used , I forget the name, Delco maybe not sure
I believe the origional Chrysler design, a reduction gear type starter. The earlier Hemi and some of the later versions (not current venue hemi's) used a direct drive starter.I thought so, Thank you. What about a starter motor ?
yes that's the one, IIRC , they were 100 amp high outputI think the brand name you are searching for is: LEECE-NEVILLE. They sort-of resemble a Delco 12SI series, a high output design. The Leece-Neville units were used in high amperage needs....police vehicles and luxury car requirements.
BOB RENTON
