JG1966
I just did my first leakdown/compression test on 340. 11-1 motor. Did test with 90 psi at TDC at operating temperature (although motor obviously cooled down a bit during 2-hour process). Motor runs strong but was getting some blow by. Here are the results
#1 170 compression -- 2.5% leakdown
#2 168 -- 5%
#3 168 -- 3.75%
#4 160 -- 12.5%
#5 167 -- 11.25%
#6 159 -- 4.5%
#7 165 -- 11.25%
#8 151 -- 16%
Nos. 4, 7, 8 are leaking from exhaust valves (exhaust pipe) and rings (breather hole). No. 5 is leaking from rings. I didn't add oil and retest "wet" on any of them.
Also, the leakdown connector was leaking a bit at spark plug hole on Nos. 4 and 6. I think it was connector not sealing perfectly because there was no leak taking compression test (with a much higher psi).
Do these numbers make sense/warrant a teardown this winter?
How can No. 5 have a strong compression number and still have a relatively high leakdown %? Same with No. 7.
Is there a way to try to remedy leaking exhaust valves before/if pulling heads (Seafoam, hitting valves with nylon hammer, etc?)
Motor runs well and I'm a bit of a newbie. Just looking for some feedback. Thank you!
#2 168 -- 5%
#3 168 -- 3.75%
#4 160 -- 12.5%
#5 167 -- 11.25%
#6 159 -- 4.5%
#7 165 -- 11.25%
#8 151 -- 16%
