Leaking intake Gaskets on my 1970 440
eastyorker
2:27 AM
Canada
The 440 in my Road Runner just started leaking from what looks like the crossover section. Exhaust will come out on the pass. side of the intake toward the Carb.. I assume it's blown gasket? Which gasket should I use to eliminate this? Only thing I know of the intake is it says Mopar on it and its aluminum.
If you're in a cold-weather climate & you use the car in colder weather, consider using the pan with the hole for the heat crossover.
