Mike Gaines
- 11:26 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
My car is heavy (about 3800lbs on the line) and you need a stiff sidewall tire so the weight of the car does not crush the tire on the launch. The tubes just make the tire sidewalls stiffer...and to run 17lbs of air so the weight of the car would not make the tires cup up in the middle.mike, stiff or soft does it matter on launches i am guessing yes but why. i'm thinking soft to stick better and hard for tire spin control. what do tubes have to do with it.
This all worked fine until I took 183lbs out of the car....120lbs of that was from the rear axle back with the installation of a pin on fiberglass deck lid (10lbs versus 70lbs for the stock steel deck lid) I also took out 1 of my 2 optima batteries and replaced the steel floor in my trunk with an alumimum floor and ditched the 10 gallon plastic fuel cell for a 5 gal aluminum fuel cell....120lbs total out of the trunk area.
