Limit Vacuum Advance Arm Travel Distance
Gripper
9:53 AM
Columbia South Carolina
Trying to limit the travel on Mopar big block distributor vacuum advance arm.
I have tried the band aid metal piece and wrapping the wire around shaft arm to limit amount of travel movement both don't work very well.
Is there an easier way ??
Attached pictures.
Thanks Gripper
Contact @HALIFAXHOPS maybe he has one that already has the particular amount of advance degrees you want.
Slot the hole where the advance unit sets on the plate. That way when the arm starts it's travel it won't move the plate until the end of the slot contacts the pin.
I cut a washer to make 2 small steel blocks and JB Welded them under the arm to limit the travel. Thinner or thicker washers to vary the amount of allowable advance.
I am useing the 9.5 plate like Halifax has.
Perfect for my 440 and cam, 1 light spring and it's all in right were the cam and T quad turn on.
Initial is sitting at 17
