Location of Turn Signal Flasher ????
Mike Gaines
2:31 AM
Ahwahnee, (Fresno) California
I cannot find the "turn signal flasher" on my 1966 Dodge Coronet 440.Can anyone help me find it ?
I am believing that it does have one, right ???
PLEASE.....
Thanks, Mike
Both the flashers are located under the glove box. Reach up around the bottom of the frame. If they are original, they will be rectangular and clipped to the frame.
I still cant find the turn signal flasher....I have looked up and around the glovebox and up and around the ashtray....to no avail...I am begininng to believe there is NO flasher....but the turn signals do flash, like they are supposed to.
Any other help out there...
THANKS
Can you hear it when it is flashing....that's how I found mine on my 65 Coronet.
On both my '66's it is to the left of the ashtray (sitting in seat) there should be clip to hold it.
66 flasher is not under the glove box....they are in a bracket attached to the top of the ashtray bracket....if it's still there...but you need to look under the drivers side of the dash, to the right of steering column
