rakort
I'm in the camp of a master cylinder issue. Rod too long won;t let the piston all the way back and release residual pressure in the system from heat and expansion. As I recall it's kind of like a clutch, and ya need a little free pedal to ensure the piston comes all the way back.
If the rods not allowing the piston to return to the full rest position, fluid pressure will eventually build up and the brake will start dragging. Let it sit a bit and pressure will bleed off again, until the next ride. Even the smallest degree of excess rod length will cause this issue. Easy to check, and even easier to fix.
