Nirvana
Anyone have one of these they don’t need? I was going to buy one from summit but thought I would see if anyone has one. I have some big block 3 piece kickdown stuff that I could trade as well. Let me know.
Thank you!I think that I have one. I'll look tonight
I’ve heard that the brackets are cheap feeling and bend easily. I was going to just order one from summit but a reputable source gave them the thumbs down. You think they are ok?I bought Lokar knock-offs from eBay. Looks and works the same for a fraction of the price.
Did you have any luck?I think that I have one. I'll look tonight
PM sentDid you have any luck?
I already had a billet carb bracket I bought for my Street Demon carb. So, I didn't use the supplied brackets there. I did use the transmission kick-down bracket on the trans end and it seems fine.I’ve heard that the brackets are cheap feeling and bend easily. I was going to just order one from summit but a reputable source gave them the thumbs down. You think they are ok?
If I can’t find a used Lokar on here or FABO I will probably go that route. I found one that has the return springs and bracket for $30 shipped. Hard to beat if it works as it should! Thank you for your input.I already had a billet carb bracket I bought for my Street Demon carb. So, I didn't use the supplied brackets there. I did use the transmission kick-down bracket on the trans end and it seems fine.
Even the Lokar brackets are just chrome plated stamped steel.If I can’t find a used Lokar on here or FABO I will probably go that route. I found one that has the return springs and bracket for $30 shipped. Hard to beat if it works as it should! Thank you for your input.
