Looking for info two fender tag codes on a 71 GA4 Charger.
71dodgechargerrt
6:02 AM
Tiny, On
For a friend, top right of Lynch Road car tag. My R/T has 444 042 which is 440 4 bbl, and 323 rear.
His is 359 engine 330 axle. Any help on these codes is grateful. He has no build sheet.
These are to only ones I have seen for 71
REAR AXLE / BRAKES​
Code Number​
Description & Application​
042​
3.23 open, 8 3/4, 10" rear drum - front disc/LD drum
043​
3.23 S/G, 8 3/4, 10" rear drum - front disc/LD drum
044​
3.23 open, 8 3/4, 11" rear & front drums
045​
3.23 S/G, 8 3/4, 11" rear & front drums
046​
3.55 S/G, 8 3/4, 11" rear & front drums, (A36 Pkg)
047​
3.55 S/G, 8 3/4, 10" rear drum - front disc, (A36 Pkg)
048​
3.91 S/G, 8 3/4, 11" rear & front drums, (A31 Pkg)
049​
3.91 S/G, 8 3/4, 10" rear drum - front disc, (A31 Pkg)
050​
3.45 S/G, DANA 60, 11" rear & front drums, (A33 Pkg)
051​
3.54 S/G, DANA 60, 10" rear drum - front disc, (A33 Pkg)
052​
4.10 S/G, DANA 60, 10" rear drum - front disc, (A34 Pkg)
Thanks guys. Just the axel code to figure out. Maybe a 2.76 which was standard.
My first car was a 318 in the mid 70's no one looked at fender tags then.
To expand on this a bit - 359 is for a 318 2bbl engine that is going to be mated to the Auto trans, and outfitted with A/C. Double check that Axle code - possible 033? I have 029, 030, and 031 as 8-1/4" axles.
Edit - if it is 330, maybe that is the axle code for a 030 axle with a sure grip unit.
