Looking for Max Wedge heads....
crossram 426
7:27 PM
Australia
Feedback: +0 / =0 / -0
Unless you are doing some sort of oem resto,You might consider some aftermarket heads with the max wedge port so you could still use the crossram.
yep that's what I'm looking at as they're quite reasonable in price...ie under $1500
aren't yours only RB heads? not max wedge?
Big Block Mopar Head Casting Numbers
Casting # Chamber Vol. Intake Valve Exhaust Valve Comments
2406158 73.5cc 2.08 1.6 1967 440
2463200 73.5cc 2.08 1.74 1963 361/383/413/426
2406209 81cc 2.08 1.88 1963 Max zWedge
3751213 2.08 1.74 1973 400/440 motorhome
2402286 81cc 2.08 1.88 1962 413 Max Wedge
2206324 2.08 1.74 1961-67 361/383/413
2268341 1965 426
3462346 79.5cc 2.08 1.74 1971-up 383/440
3462346 81.5cc 2.08 1.74 1972-73 400/440
4006452 81.5cc 2.08 1.74 1976-78 400/440
3614476 86+cc 2.08 1.74 Stage 4
1851509 73.5cc 2.08 1.6 1959 361/383/413 HP
2406516 73.5cc 2.08 1.6 1964-67 361/383/413/425 300L
2406518 86cc 2.08 1.88 1964 Max Wedge
2408520 73.5cc 2.08 1.6 1964 late 300K with ram intake
2128521 73.5cc 2.08 1.6 1960 361/383/413 300F
2128522 73.5cc 1.94 1.6 1960-61 361/383
1851524 1958-71 350-413 Truck
2264547 1960-71 413, 361 Truck
2402557 73.5cc 2.08 1.74 1963 300J & early 300K
2202594 1958-71 Truck
1737622 73.5cc 1.94 1.6 1958-60 350/361/383
1737635 73.5cc 1.94 1.6 1958 350/361
2466676 1971-77 413, 361 Truck and Maring
1844705 73.5cc 1.94 1.6 1958-59 350/361/383
1944705 1958 350, 1961 361
1406740 1.94 1.6 1958-59 HD 361 Truck
2406740 1963-68 361, 413 Truck & Marine
2406780 1965-67 383 Truck
2806887 426 Marine & Industrial
2843906 79.5cc 2.08 1.74 1968-71 383/440
2899913 1960-71 413 Truck
2708915 73.5cc 2.08 1.74 1967 440 HP
2206924 73.5cc 2.08 1.74 1961-62 361/383/413, 1961 300G, 1962 413 300-H
2899943 1971-77 413, 361 Truck
3769975 83.1cc 2.08 1.74 1974-75 400/440
yes. If they aere max wedge heads, I would want 1,500. They are still period correct and closed chamber. I didn`t think it was a huge deal as you were looking al aluminum heads, up to you just offering.
If he wants to use an original configuration MW crossram those 62 heads will not work. MW heads have a very different intake port size and design. The 361 heads have the standard intake port like other big block heads.
A&A Transmissions sells a reprodution crossram that is meant to be used with the non max wedge big block heads like 906's, 542's and your 62 361 heads etc.
