Looking for opinions on what parts to use?
Heimedw
9:12 PM
Ontario
Just looking for some opinions on a few parts I can't decide what companies to go with. I'm building a 512 around the 600hp range. The parts I would like some feedback are, harmonic balancer and timing chain. I was looking at summit double roller timing chain and professional products balancer? Keep in mind The build is internally balanced and I want to run the stock belt and accessories.
Buy tghe best timing chain you can get its ade by an austrailain company available from Bob mazzolli racing or mancini Mancini has the best balancer for the money..
If it was me I'd just call Hughes Engines and ask them what brand is currently working the best. They carry a few different dampers and chains and they'll sell you whatever their customers are having the least problems with. I'd probably use a BHJ damper and a Pro Gear chain if I was building an engine today but I've used ATI, Fluidamper, BHJ, etc. over the years. I've used Rollmaster, Cloyes, Pro Gear, etc for timing sets. I'm not sure it really matters too much as long as you can find a quality part that fits you should be good.
What kind of RPM average are you looking at ? Besides the water pump and alternator/generator what other accessories do you plan on running ?
Get one with an Ewiss chain chain matters rest of the brand does not
Max rpm will be 6000rpm and running power steering.
Thanks for in input guys. I'm going to check out Andys recommendations.
Andy what's your opinion on timing sets with the torrington bearing?
I use an SA Gear double roller with thrust bearing. Dampener I would like to use an ATI, but for now stock is working just fine.
We use the Cloyes 9-3625TX9 regularily on our builds. It has the Torrington Bearing, no issues, works well.
Powerbond Harmonic Balancers are a cost effective alternative, they come in both std Street and SFI approved, no issues to report when Balancing, usually within 1 gram from neutral.
Sold under PB1112N for the oem replacement, or the SFI approved PB1112SS.
On another note:
It's a good idea for best results and when performing REAL Rotating Assembly Balancing, to make sure whoever Balances the Crankshaft for your Recip/Rotating Bobweight uses whatever Timing Gear & Oil Slinger you are actually USING ?, because we have seen discrepencies between manufacturers lower timing gear thicknesses by as much as .030", which positioning any potential Harmonic Balancer "imbalance" further IN or OUT can have notable effects on the left plane.
No matter,
as is said, "poop will run".... and close enough for "horseshoes and hand grenades" when buying the pre-balanced Rotating Assemblies ? never know WHAT they used or didn't use on the Crank when Balancing(usually nothing), let be an actual Harmonic Balancer/Slinger/Gear.
just say'in....
that's that vibration you can feel on the Dyno room concrete floor when revv'ing under load using the pre-balanced Rotating Assembly Kits.
Challenger340 you speak the truth. People buy "pre balanced assemblies and get poor results.
Please don't get me wrong, they RUN, just say'in.... people should not confuse buying a "balanced" Rotating Assembly with "Balancing the entire Assembly" using their Parts that will be bolted onto the engine in it's final running configuration.
Things like the Flywheel, Harmonic Balancer, Timing Gear/Oil Slinger spacing can.... and do make a difference ? let be how many of those pre-Balanced Kits do you see where all 8 Connecting Rods and Pistons have been "equalized" ? Most Kits you buy the Rods & Pistons have never been touched !
Big Ends are NOT equalized, Rod "Totals" are NOT equalized, Pistons are UN-touched, they just weigh and use "averages.... close enough I guess.
No wars wanted,
just pointing out the stacked tolerances.... a coupla grams here... a few grams there... then Bolt on a few unknowns ? just NOT the same and should NOT be confused IMHO with a REAL Balance job ?
But hey.... WHO cares, guys want PRICE !
Agreed!^^^^^^
How would you go about balancing with a Fluiddamper?
Doug
