funknut
A bit of background to start:
440, .030 over, 10.5:1 compression 440 source aluminum heads. Performer RPM intake, Edelbrock 1413 (800 cfm, mechanical secondaries, e-choke), spark plugs are NGK BKR5E and probably have < 600 miles on them. I haven't touched the carb since I got the car, so I haven't gotten in to look at the jets and don't know what they are. I've never tuned a carb and currently trying to figure out how to read plugs.
A while ago the mechanical fuel pump failed, I got a new Edelbrock unit and it was putting out crazy high pressure ( ~12 psi or so). I installed a fuel pressure regulator and had it dialed for about 6 psi, which I thought was reasonable and between the 4-7 recommended in the paperwork and ran it that way for a while. Still seemed to run rich, so I did a bit of asking around and was told that 6 psi it's on the high side for Edelbrocks, and I should really be targeting closer to 4 psi. About 50 miles ago I set the pressure to 4-4.5 psi and the fuel smell does seem to be less.
Yesterday as I was parking in the garage I shut it off and it "coughed" once, maybe twice. It sounded like dieseling/auto-ignition, so today I pulled the plugs to see if I could see anything obvious. Maybe things had gotten carboned up from running too rich from high fuel pressure?
Here are the plugs:
1 definitely looks the worst/darkest, 4 and 3 are close behind.
Which of these (if any) is closest to a 'good' looking plug?
I'm looking for suggestions as to my next move.
- New plugs and run for X miles, see what they look like?
- Reinstall these plugs and run some Berryman or SeaFoam through to try and clean them up?
- Get into the carb and see what jets are in there?
- Something else?
Thanks in advance
Here are the plugs:
- Something else?
Thanks in advance
