- 1:52 AM
- Jan 23, 2009
- New Jersey The State of Tax Theives
The original style is being reproduced by pirate jack
Here are two photos of my 383’s vacuum pull at idle (8 to 10 inch hg fluctuating) and at a bit over 2000 RPM (17 inch hg). These vacuum readings were made with the booster disconnected.
The cam specs in my car are unknown. After connecting the rebuilt booster, the brakes seem to work adequately. I’m able to stop the car and don’t have to apply much pressure with my foot on the pedal to do so. I’ve only driven the car one time, at speeds up to 60 mph, since I completed the brake rebuild.what cam are you running(maybe i missed it) I'm curious
check for vacuum leaks / adjust timing & carb air / idle ? i found another 3~4" off idle by readjusting the carb. still didnt help ...
i haven't finished installing my vacuum pump yet. i was half way done then my AR parts showed up. so i changed gears and haven't been back in the garage . it's been so cold here lately & i refuse to turn the heat back on in the house
