toearley
1971 440 4bbl 4spd in 74 body. Have overheating problems on "city" type stop and go traffic -- worse of course on hot summer days. I've taken things apart, flushed radiator, and have new thermostat. In breaking things down, I'd like to replace the intake neck, water pump and housing with aluminum. I've heard Milodon is a good way to go, and read a lot of opinions on fins, number of, spiral, etc. I also plan on a new fan and all new hoses. I should mention I have taken off the AC and all associated parts -- never worked, and never used it. I've replaced the distributor late last season and am still working on the timing -- I understand timing could be part of the problem. Now that I've got things broke down, I also will be replacing alternator/brackets and replacing or restoring remaining pulleys.
MY QUESTIONS ARE: Does anybody have a reliable source for aluminum water pump, neck and housing (and all hardware/gaskets)?
Does anybody have a go to water pump brand?
If I go from AC to non-AC should the pulleys be changed out to a 2 groove? If so, what's a reliable source for pulleys?
Any tips on low speed overheating problems or installing/testing any of this would be helpful.
THANKS.
THANKS.
