The numbers on K-frame that I can read are 3058 1.There are some pretty good indicators for build dates at Lynch Road. While not 100%, we have found patterns in the production of components.
What is your K-frame date? It is located right above the radiator yoke support facing forward. If you provide this along with your VIN, we can take an educated guess on your actual build date.
D
My VIN is RH23F9A202661.
Can you tell when it was built?
3658 1 could beMario,
Other VIN we have around yours indicate a early January 1969 build, most likely the 6th or 7th. Your K frame date as you report it does not make sense as 3058 is October 31, 1968. Way too early. I am going to bet if you look at the date a little closer you will see it is actually 3658 (December 30, 1968) which makes complete sense with what we see for K frame versus SPD.
I hope this helps with your questions.
D
Mario,
D
You’re my hero! Daily driving a big block...My daily was built there. 383, starts everyday. It was 27 degrees this morning, and I made a quick trip to Shoprite. Snapped a pic.View attachment 1198799![]()
