Machine Shop Costs, 440 Build
I got the following estimate from a local machine shop.
I am not going to buy anything from Comp Cams.
Other than that, what do you think of the costs? Thanks
Ballos EstimateQuantityPriceTotal
LABOR
Assembly - Hourly
5.00​
$125.00​
$625.00​
Clean & Magnaflux Block
1.00​
$175.00​
$175.00​
Install Cam Bearings
1.00​
$100.00​
$100.00​
Bore Job Set Up Fee includes 1st hole .030
1.00​
$150.00​
$150.00​
Bore job - Each Additional Hole .030
7.00​
$22.00​
$154.00​
Install Freeze Plugs
1.00​
$60.00​
$60.00​
Polish Crankshaft Std/Std Order .001 US
1.00​
$70.00​
$70.00​
Recondition Connecting Rods
8.00​
$30.00​
$240.00​
Balance 8 Cylinders
1.00​
$275.00​
$275.00​
Gap Rings
8.00​
$15.00​
$120.00​
Resurface V8 Block
1.00​
$300.00​
$300.00​
Valve Job - Setup Pair Heads
1.00​
$200.00​
$200.00​
Valve Job - Per Seat
16.00​
$15.00​
$240.00​
Resurface Cylinder Heads
2.00​
$70.00​
$140.00​
Install Valve Guides
16.00​
$15.00​
$240.00​
Install Valve Seats
8.00​
$25.00​
$200.00​
Hazardous Waste & Shop Supplies
10.00​
$5.00​
$50.00​
Buffer
1.00​
$500.00​
$500.00​
PARTS
$0.00​
Speed Pro L2355F .030 Speed Pro Forged Pistons
1.00​
$515.00​
$515.00​
Hastings 2M-592-030 Rings
1.00​
$105.00​
$105.00​
King MB5116HP-1 Main Bearings
1.00​
$115.00​
$115.00​
King CR806HPN-1 Rod Bearings
1.00​
$100.00​
$100.00​
Dura-bond PDP-17 Cam Bearings
1.00​
$55.00​
$55.00​
ARP 145-6002 Rod Bolts
1.00​
$95.00​
$95.00​
SBI-1687-2 Exhaust Seats
8.00​
$3.00​
$24.00​
340-1028BR Bronze Guides
16.00​
$6.00​
$96.00​
Ferrea F-5052-8 Intake Valves
1.00​
$160.00​
$160.00​
Ferrea F-5055-8 Exhaust Valves
1.00​
$160.00​
$160.00​
Comp Cams 23-700-9 XR274R Solid Roller 2500stall
1.00​
$630.00​
$630.00​
Comp Cams 829-16 Solid Lifters
1.00​
$790.00​
$790.00​
Comp Cams 26953-16 Valve Springs
1.00​
$312.00​
$312.00​
Comp Cams 627-16 Valve Locks
1.00​
$70.00​
$70.00​
Comp Cams 741-16 Valve Retainers
1.00​
$98.00​
$98.00​
Rollmaster CS-5140 Timing Set
1.00​
$170.00​
$170.00​
Comp Cams 11621-16 Rocker Arms
1.00​
$1,150.00​
$1,150.00​
Oil Pump Driveshaft Bushing
$0.00​
Gasket Set
Shipping Cost
$69.95​
Sub Total
$8,553.95​
Sales Tax
$278.70​
Total
$8,832.65​
Is the cost for line boring the block buried in one of those items?
Thanks All. I have not paid or authorized anything but cleaning and measuring. Appreciate shared experiences.
My shop is on the high side of prices, apparently, although I have a knowledgeable friend in Indiana who says the labor is normal for his area.
I don't know what Buffer is. Need to ask.
The price is supposed to be assemble short block and heads. Need to ask if cam is included.
Ballos is a big shop that does 2000 orders/jobs per year, according to the owner. Part of the problem may be that they don't need my business.
I may need to look into a different shop doing the work. I have a call out to another acquaintance who is knowledgeable about our area. He may recommend someone else.
I assumed buffer is just for you to know the cost of labor could go up $500 due to unforeseen issues, damaged threads, etc.
Do a break-out of what he wants to do the heads - parts and labor. I think that will speak for itself.
