glassman
If it has the side brackets like the one pictured above, it is mine and has a warrantyI think my scoop might be yours. A larger than AFX scoop.
It has 2 studs in the front molded in.
the rear of the hood is curved inward at the middle- the rear of the scoop is close enough as you want, measure side to side front and rear to center it.What are you guys using to make a template for a hoodscoop that has mounting studs?
Fiberglass hood to fiberglass scoop.
Anyone have any pictures on how you made yours.
Working on a 64 Plymouth Belvedere.
Never mounted one before.
correctThe 2 front studs are so long I can't get the side studs to touch the tape.
Guess I'll have to drill the 2 front holes 1st to get the others to drop down.
