QOTHL
Bigger pain in the *** than I expected but probably because I've never done it before. The next time I see the guy who says they installed his door in 2 1/2hrs I'm going to kick him right in the ***!
There's a guy on youtube demonstrating how to cut the hole for the door - I don't recommend doing it that way. I cut the sides and the bottom and then the top so that the piece fell right out.
I decided to use 1/8, 1 1/2 steel tubing. I'm not sure the "x" pattern is ideal for this application but like the idea. It has created some challenges for a door that opens on the front. This door measures 4'w x 6'l.
The Metabo cutter makes this easy to cut.
Fitting the hinges was a big pain. As you can see I had to weld extensions of tubing to attach the bolts.
I added tubing for support. The hinges attach to a 1/8" x 2" steel tube stud. The rest of the framing is 1/8" x 1 1/2 steel tubing.
