pearljam724
Thank you. I’m not worried about pressure. I understand it’s low pressure there. I need a hose that will hold up to the oil and heat. This one didn’t hold up for a few months. That’s the only reason why someone would want hydraulic. To withstand oil. But, I also know for a fact my valve body seals were shot and most leaking was due to that. I replaced those today, with hydraulic o-rings. Old ones were hard as granite and most likely original. That combined with the last half inch of hose was desolving. It was a poor quality hose, as most are today.I don’t think the return line has much pressure. You don’t need reinforced lines for that application IMO.
My reproduction power steering hose has been on for almost 10 years and it has no reinforcement.
The pressurized side.....absolutely needs to be rated hydraulic hose for the pressure it will see. (I believe around 1300 PSI)
Even though fuel hoses aren’t oil resistant. I believe a good quality fuel hose should hold up for a while. I’ve fought with this leak for nearly a year now. Everything is new, etc.
Up until today, I minimized a lot of it. It was barely sweating. I think the new seals and a good hose will put it to rest. But, I’ve thought that a few times. Lol ! The power steering is a bad set up on these cars in my opinion. The steering is incredibly effortless. But, too leak prone. The pump/reservoir constantly leaks a little somewhere, the hoses constantly leak a little somewhere, the gear box always sweats somewhere. Cars that are driven. Not garage queens, lol !
