Mark Barnes
Not the kind of thing you'd think someone would admit to, eh?72 Hours to remove an Oil Filter
WOW
WOW
Lol. Screw those up and it can be a lot more complicated a fix than an oil filter!Next Month's article... Same guy changes spark plugs![]()
Did that, plus a few coils and plug wires this past year on my wife's 03 2500.. Wires are fun all 16 of them! 2 1/2 hrs with taking breaks cause my back was killing me standing on a step stool leaning into the engine compartment. Fired right up and got all of them right the first time..I will admit that a spark plug change in a 5.7 equipped 2003-2008 Ram truck S U C K S.
The fastest time I had was 1 1/2 hours.
Have used an air chisel on more than a few semi’s in my day. You just have to show the engine who the boss is!Working as an auto tech 45 years there was more than one filter that the can got ripped off. If the seal was dry and it was installed to tight, good luck. Learned two things. Before the can starts to twist grab it with 2 oil filter wrenches at the same time. Most times that will work. The cup type by itself can tear the can off. If the can has to come off or tears you are at option two. Break out the air chisel. Grind a bit with a notch in it. Place the notch in one of the holes and have at it. At times the hole will tear. You may have to go to a 2nd hole. Filter brand doesn't matter. I've had this happen with many different brands.
Doug
Was thinking the same thing; next headline: Guy takes three weeks to remove plugs.Next Month's article... Same guy changes spark plugs![]()
I put a dab of Earl all the way around the rubber gasket!I sure hope he didn't put a Fram back on it!
This is what happens when someone doesn't use a thin smear of oil on the gasket and then over tightens it.
Oil.or a smear of grease.I put a dab of Earl all the way around the rubber gasket!
