Just want to share my experience with Mancini Racing, who I've bought a lot of parts from. I ordered a custom built aluminum radiator using their form on their site. Less than 2 weeks later it arrived at my door on the West coast. I installed it and noticed that it had cooler fittings in the bottom tank, which I specified I didn't need on the order sheet. I went ahead and plugged them since they're not visible anyway. I then polished the upper tank and when I went to install the upper hose it was quite apparent that the hose fitting was installed 1" further to the passenger side than I specified. Again, no big deal. I took the old hose to the local O'Reilly's and went through their stock (over 200 hoses). Found one that could be modified to almost fit correctly. Bought it, modified it, and then I knew that I wasn't going to be happy with the look. I called Mancinis and told Wes what the problem was. He checked the original spec sheet and agreed that their vendor had made errors. He gave me a couple of options. I elected to have him send me a UPS call tag and send it back at their expense. A week and a half later I received a new radiator built correctly as well as a phone call from the vendor apologizing for their mistake. The new radiator fits and works perfectly. Thank you to Mancinis for taking care of this customer.
