Manual steering box grease/lube?
wedge5
6:05 AM
Central IL
What kinda grease/lube do you put into the steering box? How do you know if you have enough in the box.
As far as I know the box was packed with grease. I don't think that means pump it up until it oozes out every seal, but at least the recirculating ball part should be full.
Took the filler cap off and the gear was covered in grease but wanted to make sure that was right.
