Black63
Had this on the Brakes, suspension forum but got nowhere so I figured I'd try here!!!!
Hey guys....doing some parts ordering for the "Rust Revival" thread 63 330 and after doing a quick search of the site I'm still confused on just what master cyl I'll be needing.
I'm using 12", pin style Calipers/discs from a 78 Charger and a 67 Plymouth rear axle. (10" drums and 7/8th wheel cylinders I believe)
I was figuring on staying with manual brakes, but If power is what I must use I'll go that route...although that will require some complicated sourcing of parts.
What master cylinder is going to work and give normal pedal stiffness?
My wife will be driving it at times so I don't want a rock hard pedal!!!
Thanks!
Thanks!
