Ginja
Hi all,
I upgraded to discs on my 69 Coronet using a kit with wilwood calipers, a bendix booster and master and oe style master cylinder from Cass. Kit works great, but I've an odd leakage problem from the master cylinder cap - wondered if any of you had experienced it?
If I start with a clean system - dry seals and cap lid on the reservoir I can drive the car for a day with no issues. The next time I use the car it will leak from the cap at some point (not sure at what point - driving or cooling down). On removing the cap after leaking the diaphragm in the cap washer will be 'down' into the fluid. My theory is, first run fluid gets hot, expands, air is forced out (there is a tiny channel in the inner cap lid to facilitate this). Fluid cools, and contracts sucking down the diaphragm. Next use of the car this acts as a pathway to the lid for the fluid which is then pushed out when the fluid expands. My question is, what am I doing wrong - is the fluid too high (about half an inch from the top - enough to connect with the diaphrgm when 'down') or may I still have air in the fluid somewhere? There is no spongyness to the pedal - well, not that I can notice. Car does have hooker headers and a choppy cam so gets hot under the hood, but I don't beat on it.
Any ideas folks? Thanks!
Mark
Mark
