- 9:41 PM
- Dec 21, 2021
- Miserable Smells TX
I’m just going to eliminate the vacuum booster, and overly simplify everythingDon't get a chevy just yet!
"Disc doesn't require the rcv but drum does."I was thinking residual check valve in the master and/or possibly having the m/c mixed up on routing. Disc doesn't require the rcv but drum does. Greg found out awhile back that he had the ports mixed up on the mc as who was who. When the brakes won't release, if you open the bleeder screw on a caliper when this is happening, does it squirt and then the rotor spins? Different matter but awhile back I had to replace the mc on the wagon as it was leaking out the back. It's a Doc Diff conversion pack so I emailed him to find out application. Never got a reply back so I winged it. 75- F-body[ aspen/volare] disc unit. 1 1/32". Got one from the Rock, no leaky now. And I did adjust the rod in the booster out.
Just because it's new does not mean it's good...He’s got stainless braided front flex lines, so I’m pretty sure it’s not the lines. The OP bought a rebuild kit for the calipers and he sent me a pic, nothing wrong with the piston. Waiting to see what the passenger looks like. I mention to the OP that he should turn the air down to 5psi and blow the front lines out to make sure there’s no obstruction.
