Vermont Rock
70 Road Runner. Dual master cylinder. Appears original, but... ?
I'm removing the master cylinder to replace it with a Wilwood system. Usually the M/C is attached directly to the fire wall by nuts threaded onto studs. But mine is mounted on a larger black plate. Both the plate & M/C show only blind plugs ( caps ?, covers? ) and they cannot be removed.( no hex heads or nuts, just smooth little mounds ) Looking inside, I see no way to reach these studs and I'm not sure if I even see nuts on the back. In 2 locations there are bolt heads. This is pretty confusing and I would appreciate some advice. Thanks, Rocket
Yes, it's Christmas. But what better gift to give yourself than something for the car ?
Merry Christmas !!
Merry Christmas !!
