BB69R/T
If the lower contact point gap of a mechanical voltage regulator (69 Dodge) is .014 + /- .002, what is the upper contact point gap? Thank You.
The upper point gap in the de-energised state is ZERO. The contact is closed when the key is off. It fluctuates between upper position and mid position depending on the battery's state of charge.If the lower contact point gap of a mechanical voltage regulator (69 Dodge) is .014 + /- .002, what is the upper contact point gap? Thank You.
