JG1966
I just installed a mini starter in my 340 (after pulling engine for winter refreshening) and it grinded teeth for a second when I first tried to start it.
The second time I turned motor over, it fired right up.
When I started it again two days later. Same thing. Grinded first time I turned it over, then started fine. Tried it again today. Same thing. Grinds first try, then starts. I don't want to damage flywheel so I'm done with it until I fix it.
My big original starter worked fine before and the flywheel teeth appear to be fine. All the bolts are tight and starter seems to be seated correctly.
Could this be ground/electrical related? That would make the most sense (based on engine being out, painted and all wires disconnected).
Before I pull starter, I still have to get under car and take a look at what happens when I engage starter but I'm working solo and was hoping for some possible issues beforehand. Thanks.
