Most, if not all "mini or compact" new starters use rare earth permanent magnets in lieu of wound field coils, to reduce physical size and therefore deliver more amps to the armature for greater starting torque. ......just thought you might like to know the reason....New aftermarket starter. That says it all. Get the starter rebuilt by a knowledgeable, reputable rebuilder.
I'd assumed it was the original configuration. OP did not indicate it is a mini/compact starter.Most, if not all "mini or compact" new starters use rare earth permanent magnets in lieu of wound field coils, to reduce physical size and therefore deliver more amps to the armature for greater starting torque. ......just thought you might like to know the reason....
BOB RENTON
Doesn't matter.....both have the main current carrying contacts on the back of the solenoid, which operates the "Bendix" and engages the drive AND powers the motor....same principle.....I'd assumed it was the original configuration. OP did not indicate it is a mini/compact starter.
To validate..'adequate current availability not voltage'........
There is NO current flow without voltage. And the current that the starter draws is a looooot more than 75 amps, actually several hundred amps when cranking.
Ohm's law prevails [ E = I x R ]......IF ....resistance (R) is zero (or near zero), voltage (E) drop will be zero (or some small value), but current (I) will try to get to infinity or to the maximum available at the supply source (car's battery in this case)......limited by the current carrying conductor's ampacity.....or fusable links rating if present. .........just another example.......'adequate current availability not voltage'........
I agree totally. 10 Volts is dead in every battery I tested.That must be a realllllllllllllly 'special' battery & starter that cranks 'just fine' with 10 volts......
If a 12 volt battery tests 12.6 volts at a no load condition, and is then subjected to an actual load test, either via resistive load or an actual engine cranking test and the battery's terminal voltage drops to 10 volts, or less under load conditions, the battery is sulfated and should be replaced. As the ambient temperature decreases, the battery's efficiency drops which may result in a no-start condition. just my opinion......I agree totally. 10 Volts is dead in every battery I tested.
