Bolt-Action
Howdy guys and gals, got a few parts I'm looking to send down the road, so if anyone can use any of it, let me know!
383 BB, build date of May, 5th 1966 (1967), had around 40k miles before pulled and ran well, its been sitting inside for a couple years now but turns over by hand, it was an AC, PS motor. Still has oil in it.
727 trans was pulled with ^above motor, so they're a "mated" pair and are still together, trans shifts smoothly by hand, still has trans fluid in it.
Motor/trans are mostly complete, pulled em out if the garage for pics, I can help load (I've got a hoist and tractor with loader)
$300 for the pair
2 clutch fans, 1 has seen very little use, parts#'s still very visible and clean, also has the "engine side" on it.
1 clutch fan has seen more use but stamps are visible on fan blades.
both fans are straight make offer $-
If you need any specific pics of fans just let me know.
Water pump housing, water pump, and thermostat housing, passenger side, overall clean housing, part #'s visible, pretty clean inside,
t-stat housing good shape,
water pump turns easily but could use cleaned up.
some knuckle head tried to remove one of the heater hose nipples and snapped it off.
$45 for the complete unit.
AC compressor, the pulley has seen better days and needs replaced, fairly complete unit, I have various brackets for it, was on a later 440 with the water pump housing ^ above.
make me an offer-$
Prices are OBO, and shipping is extra, any questions just give me a holler. MIGHT split 383/727, and might do some trading.
$300 for the pair
make me an offer-$
