martin owen
Car has been running great all summer. Went to go drive it today and it has a miss at 2000rpm. If I lay into the throttle it goes away . 440,750 holley,holley elec. Fuel pump ,msd ignition.
If it randomly misses at light throttle and goes away under acceleration I would suspect a bad plug wire. It’s a strange phenomenon I don’t fully understand but have experienced it more than once.
IMO.....possibly too much or too aggressive (rate) spark advance combined with vacuum advance. OP said the pronlem goes away at full throttle (zero vacuum advance at WOT, no matter if ported or manifold sourced). Simple test: disconnect distributor vacuum and see if problem goes away. Just a thought......
BOB RENTON
The car was running fine before . Something has failed, or is on it way out. Unless he changed something that he didn't tell us about
