Mopar Battery Covers
YEARONE
FBBO Vendor
FBBO Sponsor
9:00 PM
GA
Now back In Stock Red, Yellow, and Red cap Mopar Battery covers. For B Bodies Only member use sales code FORB30 at checkout for a special discount.
https://www.yearone.com/Catalog/chrysler.b.body/electrical/battery/covers-_-post-extensions
Pardon my ignorance Wayne, what does 27 series refer to?
way to go Y-O
Is there any way to know what color caps your car came with ? or could they have come with any color ?
I am not sure but will do some research and get back.
If you want factory number/color
Your Broadcast Sheet if you have it
For instance my 71 Bee with 383 came from the factory with the optional group 27 battery / 70 amps / red caps based on broadcast sheet
Sales code F25 - $14.80 on window sticker
1971 BROADCAST SHEET - Line 3
Batteries:
The two digits are the last two digits of the factory part number of the battery installed:
20 = 59 amp
51 = 46 amp
64 = 70 amp
66 = 55 amp
67 = 70 amp
69 = 70 amp
81 = 80 amp
That is a good idea. Just pick up a normal flat top battery and doll her up.
Wonder what a real one worth? Must be a few hundred at least.
hey guys, just curious ... how do these battery covers attach to the battery? what type of battery works with these covers.... I would need a group 27 also...Rich
Group 24 battery. They sit on top of the battery and are held into place with the battery strap.
They are for Group 24 batteries and are held on with the battery strap.
Useing the measurements would be a good idea.
From the adds description...
Topper Inside Measurements are as follows:
10-5/16" x 6-7/8" x 5/8"
Post Center to Center is 8-3/16"
