rumblefish360
Bang on there RJ.IMO....at RPMs in excess of 3000, MSD (Multiple Spark Discharge) boxes simply do not have enough time to generate more than one spark per cylinder, although, the spark generated can be of a higher voltage depending on the coil's design and its turns ratio (primary to secondary or voltage applied to the primary winding resulting in the secondary voltage produced). One could observe the high voltage spark waveform using a storage oscilloscope, to watch the shape (amplitude and voltage) and number of pulses (time base) that occurs as RPM's increase. And then compare the control box's ability to work as intended or desired..... Just a thought....
BOB RENTON
Valve float control is the valve springs job to what ever rpm it’s intended for and set up at.WOW.....the "blue box went past 7000 & the MSD well past 8000 RPM"....@ well past 8000 RPM, one eould think valve float and maybe rod stretch would cause a catastrophic failure long b4 the ignition system gave up...but not knowing the specifics of the engine or test conditions....one can only speculate. Just my opinion of course.
BOB RENTON
Con-rod stretch (amount) is a quality & type of material issue.
That’s one thing I liked about the MSD. Easier starts with longer lasting cleaner plugs. The whole ignition system is a little pricey vs a MP set up. The extended period between spark plug changes is nice but not worth the cost which would never be recouped. (LMAO!) Though the changing of plugs is easy, it can be annoying.Dont get me wrong as even though my car was no faster with the MSD 6AL box I like that ign better the my MP orange box. It does start faster and seems to run cleaner and keeps the plugs much cleaner all year. As said the MSD is only multi-spark up to about 3000 rpm but it does still fire a capacitor of higher volts then normal ign after 3000 rpm. Ron
The orange box tends to test with some to a good bit of retard at higher rpm’s. I do not remember the figures off hand.
