PolaraFury
Does the Mopar M1 intake manifold require a specific cylinder head or can it be ran on any cylinder head?
Thank you
Thank you
Thank youBasically, if you’re running std port heads that use “normal” std port manifolds, then an easy way to look at MP intakes is…….
If it has a valley cover cast onto it, it’s not what you want.
There are 4 “normal” MP single plane intakes.
2 for B, 2 for RB.
They come in 4150 or 4500 versions for each deck height.
Generally true about factory Mopar intakes = but the M1 that I have seen had the Pxxxxxx numberGet a pic.
And an fyi……
The numbers cast into the manifold are not the part number……… those are the casting numbers, and will not match the numbers in the catalog or on the box.
