mopar performance block
mopardemon
6:43 PM
Toronto canada
I have a chance to buy this set up for 9500.00 what do you guys think
500ci 10:1 Mopar Motor Professionally built. Built for boost.
Dyno'd at 615 hp and 647 ft lb of torque
Built for forced induction
RB mopar stage 6 heads 4529335 78cc Chamber, 210cc Intake Runner
SCE 064384 Copper Head Gaskets
Mopar Performance Cast Iron Siamese-Bore 426 Hemi Block Stock Style look 2468330-M 4.380" – Capable of 4.500 Bore and 572Ci Based on the 1964-1971 426 Hemi Block Block is O-Ringed
Forged Pistons 10-1 Mopar Performance 4876453
BME Billet Aluminum Rods BME 6.760 Aluminum Rods std pin (std 440 length)
Crane Billet Mechanical Roller Cam Shaft 689356
Mopar Performance Forged Crank
Crane Lifters 66515-16
Crane Springs 99880-16 1.950-2.000 Installed Height 250 seat 700 open
Crane Adjustable Rocker Arms 64792-1
Stainless Steel valves Intake 2.140 / Exhaust 1.185
Titanium Retainers
Smith Brothers Push Rods
JP Performance Timing Set
MSD Pro Billet Distributor 8546
Milodon Pan 31150
Milodon Pump Drive 21520
Milodon Pump 21815
Fluidampr
ARP Head Studs
ARP Main Studs
Bearings
Rings
Valve Covers
Timing Cover
Water Pump
Flex Plate
Starter
Alternator
If that fits into your "build plans", and how you plan to use it, I think that is a very nice deal, seeing as it has been run & dyno proven. You may need to change that pan for fitment, depending on your specific car...
I think you should let me evaluate it for a couple of years and check back with you.
:D
If I had the money, I'd buy it right NOW!
the only thing I would have to change I think is my k member I want it for my 70 gtx
