Mopar Product Questions?
beanhead
Easily Offensive
8:46 PM
Wackyfornia
Hi @Ccas, I have a couple of questions I hope you can answer.
I know you try to get a factory fit on all possible models but I've read of instances where the mounting holes had to be slightly slotted/enlarged for the radiator to be bolted in. If such a (minor and easy) modification is done, is the functionality of the radiator still warrantied?
On the Cold Case website it says "once painted they will look like original" and I think I've seen recommendations from you or maybe a different rep to use a metal-etching primer and black paint...I like that idea, but once painted is the functionality still warrantied?
I do like the look of your product and have had good recommendations on the function but I want to be sure I don't void any warranty in case of something like a weld leaking later or a small crack that couldn't be seen before installation and use.
Thank you!
