FOR SALE Mopar to HEI conversion Mount
Canadian1968
4:25 PM
london
Feedback: +2 / =0 / -0
These are a conversion mount that allows you to run an HEI module in place of a factory Mopar ecu.
This mount uses the factory mopar plug that is on all mopar electronic conversion , or factory mopar ignition from the era. Both 4 and 5 pin work .
Using this mount , the swap is as easy and unplugging the factory ecu and plugging this mount in. You will also need to bypass the ballast resistor and get the correct coil. There are numerous articles on the internet as well as on this website about the conversion. No cutting your orginal wiring!
I have 3 versions.
Original version, has the hei module mounted on the outside and wiring is easily connected to the module. Holes are labled with corresponding terminals on the HEI module . 1/8" alumium and finned heat sinks take care of heat disappation. Grounding can be done either threw mounting screw that holds module to mount or I can install a seperate grouding bolt ( shown in picture ) Thermal paste MUST BE USED between the module and alumium base. HEI module is NOT included.
Price is $ 50 US plus shipping ( Canadian residents contact me for pricing)
Second design is more classic or stealth design. The module is mounted inside a box and is not visible once mounted. Again a 2x4" , 1/8" thick alumium plate has two tapped holes with Allen head bolts to mount module to plate firmly . On top are two large heat sinks to take of heat disappation.
A grouding post is located beside the Mopar plug to keep wiring neat and tidy.
Color currently available are orange or black.
Price is $60US plus shipping (Canadian residents contact for pricing )
Last is an extreme version of the original. This version incorporates a small 30 mm fan that is mounted to the back side of the mount and blows are threw a duct system built into the mount. This provides ultimate cooling and can used if you are mounting the module where you are worried about heat , or if your are possibly mounting inside the cabin where natural air flow may minimal. The fan draw is 0.1 of an amp .
Price is $70 US plus shipping.
Payments are usually via PayPal.
I'm located in Ontario , Canada. Prices INCLUDE duty.
HEI module is NOT included but mounting hardware for alumium plate is.
If you have any question or want to make your own modifications to the design , feel free to PM.
